Hi Hans-Jürgen,
i already removed that today
http://www.egroupware.org/viewvc/egroupware?view=rev&revision=28506
Many greetings
christian
Hans-Juergen Tappe schrieb:
Hi Jörg!
In Revision 28503, you have introduced “$log=true” as a default in the
code of trunk/calendar/inc/class.calendar_ical.inc.php:
Please check if this is not just a missed local debug setting, which has
slipped in. Maybe, it helps now, in the debug phase on the field. But
it seems to use an insecure file handling (does not use egroupware’s tmp
folder but a static value).
Thank you,
Hans-Jürgen
