Hi
If i select one distribution list in calendar, than it not show events of the group. I have to reload page to view events.
The distribution lists came from an Active Directory server. Installed egroupware verion: 19.1.20200430 Docker
Thanks Zoli
How and where do you select the list?
sorry for later answer. The latest egroupware update (19.1.20200605) solved this issue.
I selected groups from calendar left sidebar:
