in EGroupware 20210503 wird mir angezeigt, dass ein neues Release verhanden ist.
Beim Ausführen von “docker-compose pull” in “/etc/egroupware-docker” erhalte ich den Fehler:
yaml.scanner.ScannerError: mapping values are not allowed here
in “./docker-compose.override.yml”, line 39, column 12
Die docker-compose.override.yml sieht folgendermaßen aus:
### docker-compose.override.yml file for egroupware-docker package
### Place all your modifications in this file, instead of /etc/egroupware-docker/docker-compose.yml.
### If you want to make some modification / uncomment eg. some enviroment variables, you also have to:
### - uncomment the service eg. "egroupware:", if not already uncommented like egroupware
### - uncomment the "environment:" section of the service
### services:
### egroupware:
### environment:
### - EGW_APC_SHM_SIZE=256M
### Please note: indention with space (NOT tabs!) matter in .yml files!
version: '3'
#volumes:
# EGroupware data stored in /var/lib/egroupware on the host
#data:
# driver_opts:
# type: none
# o: bind
# device: /var/lib/egroupware
services:
egroupware:
# egroupware images to use:
# - egroupware/egroupware: is the community edition of egroupware
# - download.egroupware.org/egroupware/epl: is the EPL / subscription version of EGroupware GmbH
# egroupware tags to use:
# - latest: recommended is to use tag latest for automatic updates incl. new stable major releases
# - 20.1: use a branch to keep on latest maintenance release for that branch, but not update automatic to next release
# - 20.1.20200613: use a maintenance release, to disable automatic updates via watchtower and run them manually
image: egroupware/egroupware:21.1
volumes:
# if you want to use the host database:
# 1. follow instructions below to disable db service
# 2. set EGW_DB_HOST=localhost AND
# 3. uncomment the next line and modify the host path, it depends on your distro:
# - RHEL/CentOS /var/lib/mysql/mysql.sock:/var/run/mysqld/mysqld.sock
# - openSUSE/SLE /var/run/mysql/mysql.sock:/var/run/mysqld/mysqld.sock
# - Debian/Ubuntu /var/run/mysqld:/var/run/mysqld
- /var/run/mysqld:/var/run/mysqld
# private CA so egroupware can validate your certificate to talk to Collabora or Rocket.Chat
# multiple certificates (eg. a chain) have to be single files in a directory, with one named private-ca.crt!
#- /etc/egroupware-docker/private-ca.crt:/usr/local/share/ca-certificates/private-ca.crt:ro
environment:
# setting a default language for a new installation
#- LANG=de
# MariaDB/MySQL host to use: for host database (socket bind-mounted into container) use "localhost"
- EGW_DB_HOST=localhost
# for internal db service you should to specify a root password here AND in db service
# a database "egroupware" with a random password is created for you on installation (password is stored in header.inc.php in data directory)
#- EGW_DB_ROOT=root
#- EGW_DB_ROOT_PW=secret
# alternativly you can specify an already existing database with full right by the given user!
#- EGW_DB_NAME=egroupware
#- EGW_DB_USER=egroupware
#- EGW_DB_PASS=
# other php.ini values to set in the container and their current defaults
#- EGW_SESSION_TIMEOUT=14000
#- EGW_APC_SHM_SIZE=128M
#- EGW_MEMORY_LIMIT=128M
# set the ip-address of your docker host AND your official DNS name so EGroupware
# can access Rocket.Chat or Collabora without the need to go over your firewall
#extra_hosts:
#- "my.host.name:ip-address"
# to use the database on the host, uncomment all the following settings to disable the internal db service
db:
image: busybox
entrypoint: /bin/true
restart: "no"
# push server using phpswoole
#push:
# nginx server of egroupware using /etc/egroupware-docker/egroupware-nginx.conf
# You want to install your certificate on the webserver/Nginx running on the host proxying to this one
#nginx:
# automatic updates of all containers daily at 4am
# see https://containrrr.github.io/watchtower for more information
#watchtower:
#environment:
#- WATCHTOWER_CLEANUP=true # delete old image after update to not fill up the disk
# for email notifications add your email and mail-server here
#- WATCHTOWER_NOTIFICATIONS=email
#- WATCHTOWER_NOTIFICATIONS_LEVEL=info # possible values: panic, fatal, error, warn, info or debug
#- WATCHTOWER_NOTIFICATION_EMAIL_FROM=watchtower@my-domain.com
#- WATCHTOWER_NOTIFICATION_EMAIL_TO=me@my-domain.com
#- WATCHTOWER_NOTIFICATION_EMAIL_SERVER=mail.my-domain.com # if you give your MX here, you need no user/password
#- WATCHTOWER_NOTIFICATION_EMAIL_SERVER_PORT=25
#- WATCHTOWER_NOTIFICATION_EMAIL_SERVER_USER=watchtower@my-domain.com
#- WATCHTOWER_NOTIFICATION_EMAIL_SERVER_PASSWORD=secret
#command: --schedule "0 0 4 * * *"
Das Problem scheint also in der Zeile “volumes:” zu liegen. Allerdings habe ich keine Idee, was die Ursache sein könnte. Ich kann mich auch nicht daran erinnern, diese Datei vor dem Auftreten des Problems bearbeitet zu haben.
Hier im Forum oder bei Google habe ich leider nichts gefunden was mich weiter bringt.
Hat mir irgendjemand einen Tipp?
Vielen Dank!
Marc
