Ralf, All,
I have an egw 1.6 svn install (At revision 27394) that refuses to accept the path to the backup directory. Really. It is like setup has lost its mind. All the directories are there and the directories are world readable (temporarily) and still egw setup refuses to accept /var/lib/egroupware/backup as the backup path. Specifically, I have:
THE CONFIGURATION ERROR
http://localhost/egroupware/setup/index.php
Step 2 - Configuration
Your files directory ‘/var/lib/egroupware’ does not exist
Your backup directory ‘/var/lib/egroupware/backup’ does not exist
THE ACTUAL DIRECTORIES (Archlinux – web server runs as user:group http:http)
17:38 archangel:~> l /var/lib
drwxr-xr-x 8 http http 4096 2009-05-04 10:30 egroupware
17:42 archangel:~> l /var/lib/egroupware/
total 32
drwxr-xr-x 8 http http 4096 2009-05-04 10:30 .
drwxr-xr-x 24 root root 4096 2009-06-29 23:39 …
drwxr-x— 2 http http 4096 2009-05-04 10:28 backup
drwxr-x— 3 http http 4096 2007-05-22 00:37 gallery2
drwxr-x— 3 http http 4096 2008-06-18 17:42 home
drwxr-x— 2 http http 4096 2007-06-17 21:00 infolog
drwxr-x— 2 http http 4096 2007-04-23 10:42 mydms
drwxr-x— 2 http http 4096 2007-05-24 08:43 workflow
17:43 archangel:~> l /var/lib/egroupware/backup/
total 11976
drwxr-x— 2 http http 4096 2009-05-04 10:28 .
drwxr-xr-x 8 http http 4096 2009-05-04 10:30 …
-rw-r–r-- 1 http http 226272 2008-05-01 08:32 db_backup-200805010832.bz2
-rw-r–r-- 1 http http 226132 2008-05-02 23:18 db_backup-200805022318.bz2
THE INSTALLATION CHECK IS – OK
Checking the eGroupWare Installation
Checking required PHP version 5.1+ (recommended 5.2+): 5.2.10 ==> True
Checking php.ini: safe_mode = Off: ini_get(‘safe_mode’)=’’ = Off
Checking php.ini: magic_quotes_runtime = Off: ini_get(‘magic_quotes_runtime’)=‘0’ = Off
Checking php.ini: register_globals = Off: ini_get(‘register_globals’)=‘0’ = Off
Checking php.ini: display_errors = Off: ini_get(‘display_errors’)=’’ = Off
Checking php.ini: memory_limit >= 24M: ini_get(‘memory_limit’)='32M’
Checking php.ini: max_execution_time >= 30: ini_get(‘max_execution_time’)='60’
Checking php.ini: file_uploads = On: ini_get(‘file_uploads’)=‘1’ = On
Checking php.ini: upload_max_filesize >= 8M: ini_get(‘upload_max_filesize’)=‘16M’
Checking php.ini: post_max_size >= 8M: ini_get(‘post_max_size’)=‘16M’
Checking php.ini: include_path contain .: ini_get(‘include_path’)=’.:/usr/share/pear’
Checking php.ini: mbstring.func_overload = 7: ini_get(‘mbstring.func_overload’)=‘0’
The mbstring.func_overload = 7 is needed to fully support unicode (utf-8) or other multibyte-charsets.
*** Please make the following change in your php.ini (/etc/php): mbstring.func_overload = 7
*** AND reload your webserver, so the above changes take effect !!!
Checking php.ini: magic_quotes_gpc = Off: ini_get(‘magic_quotes_gpc’)=‘0’ = Off
Checking extension session is loaded or loadable: True
Checking extension pdo is loaded or loadable: True
Checking extension mysql is loaded or loadable: True
Checking extension pdo_mysql is loaded or loadable: True
Checking extension pgsql is loaded or loadable: False
The pgsql extension is needed, if you plan to use a pgSQL database.
Checking extension pdo_pgsql is loaded or loadable: False
The pdo_pgsql extension is needed, if you plan to use a pgSQL database.
Checking extension odbc is loaded or loadable: True
Checking extension pdo_odbc is loaded or loadable: False
The pdo_odbc extension is needed, if you plan to use a MaxDB, MsSQL or Oracle database.
Checking extension oci8 is loaded or loadable: False
The oci extension is needed, if you plan to use a Oracle database.
Checking extension pdo_oci is loaded or loadable: False
The pdo_oci extension is needed, if you plan to use a Oracle database.
Checking extension mbstring is loaded or loadable: True
Checking extension ldap is loaded or loadable: False
The ldap extension is needed, if you use ldap as account or contact storage, authenticate against ldap or active directory. It’s not needed for a standard SQL installation.
Checking extension imap is loaded or loadable: True
Checking extension dom is loaded or loadable: True
Checking PEAR is installed: 1.8.0
Checking PEAR::HTTP_WebDAV_Server is installed: 999.egw-pear
Checking PEAR::Net_Socket is installed: 999.egw-pear
Checking PEAR::Auth_SASL is installed: False
PEAR::Auth_SASL is needed by: EMailAdmin, felamimail. You can install it by running: pear install Auth_SASL
Checking PEAR::Net_IMAP is installed: 999.egw-pear
Checking PEAR::Net_Sieve is installed: 999.egw-pear
Checking PEAR::XML_Feed_Parser is installed: False
PEAR::XML_Feed_Parser is needed by: news_admin. You can install it by running: pear install XML_Feed_Parser
Checking PEAR::Log is installed: 999.egw-pear
Checking for GD support…: True
Checking file-permissions of . for not world writable: nn/nn drwxr-xr-x
This might take a while, please wait …
Checking file-permissions of header.inc.php for not world readable: nn/nn -rw-r-----
Checking if php.ini setting session.save_path=’/tmp’ is writable by the webserver: nn/nn drwxrwxrwt
ATTEMPTING TO SAVE THE CONFIGURATION YIELDS
Error:
I’M STUMPED, WHAT CAN BE WRONG?
I have restored a few different database backups from various installs with this egw setup on my Archlinux server, and now it just won't work.
Any ideas??
David C. Rankin, J.D.,P.E.
Rankin Law Firm, PLLC
510 Ochiltree Street
Nacogdoches, Texas 75961
Telephone: (936) 715-9333
Facsimile: (936) 715-9339
www.rankinlawfirm.com
Enter the BlackBerry Developer Challenge
This is your chance to win up to $100,000 in prizes! For a limited time,
vendors submitting new applications to BlackBerry App World™ will have
the opportunity to enter the BlackBerry Developer Challenge. See full prize
details at: http://p.sf.net/sfu/Challenge
