It is definitly not a general 16.1 problem.
Something in your enviroment, I guess …
First thing I would look at is, making sure all caches incl. browser are
cleared.
They are cleared
You wrote nothing about how you installed and/or upgraded.
Our recomendations to do a Linux package installation. There are many
ways to screw up an installation with archives, eg. copy new archive
over the existing installation (leaving old files in place).
I did use the Linux packages. I installed:
apt-get install egroupware-epl-compat
and then I installed:
It performed the upgrade with the following messages:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Suggested packages:
egroupware-epl-jdots egroupware-epl-phpbrain egroupware-epl-phpfreechat
egroupware-epl-sambaadmin egroupware-epl-sitemgr egroupware-epl-wiki
The following NEW packages will be installed:
egroupware-epl
0 upgraded, 1 newly installed, 0 to remove and 1 not upgraded.
Need to get 0 B/87.0 kB of archives.
After this operation, 113 kB of additional disk space will be used.
Selecting previously unselected package egroupware-epl.
(Reading database … 789010 files and directories currently installed.)
Preparing to unpack …/egroupware-epl_16.1.20170203_all.deb …
Unpacking egroupware-epl (16.1.20170203) …
Setting up egroupware-epl (16.1.20170203) …
PHP Warning: Cannot modify header information - headers already sent by
(output started at /usr/share/egroupware/setup/setup-cli.php:55) in
/var/lib/egroupware/header.inc.php on line 120
/var/lib/egroupware/header.inc.php on line 121
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates’,61,9)
already exist!
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates/addressbook’,61,9)
already exist!
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates/calendar’,61,9)
already exist!
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates/infolog’,61,9)
already exist!
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates/tracker’,61,9)
already exist!
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates/timesheet’,61,9)
already exist!
EGroupware\Api\Vfs\Sqlfs\StreamWrapper::mkdir(‘sqlfs://default/templates/projectmanager’,61,9)
already exist!
sh: 1: hash: git: not found
EGroupware successful updated
Any other ideas? The problem persists.
