I’ve decided to give the upcoming v14 a go,
I installed egroupware-epl from packages, on my Debian 7.5 machine:
lukasz@george:~$ sudo apt-cache show egroupware-epl
Package: egroupware-epl
Version: 14.1.20140617-1
[snip]
Filename: ./all/egroupware-epl_14.1.20140617-1_all.deb
MD5sum: d3c81825388975ec311867d27ac9b099
SHA1: 355a36640752807324cb3efddb933f9913f6a756
SHA256: 144b200d6c2e9ee9e9931d61b383f578d891c818bef01b09adc1538e156b94a1
and imported my ‘production’ backup from egroupware (1.8.004.20130322) to it.
(it is a 33MB file, with attachments/files)
I’ve 4 notes :
- trying to go into Addressbook yields
Invalid SQL: SELECT SQL_CALC_FOUND_ROWS * FROM egw_addressbook LEFT JOIN egw_accounts ON egw_addressbook.account_id=egw_accounts.account_id WHERE contact_tid=‘n’ AND (CONCAT(’,’,cat_id,’,’) LIKE ‘%,33,%’) AND (egw_addressbook.contact_owner=6 OR contact_private=0 AND egw_addressbook.contact_owner IN (-39,-21,-1,6,0) OR egw_addressbook.contact_owner IS NULL) AND (account_expires IS NULL OR account_expires = -1 OR account_expires > 1404132650) AND (account_type IS NULL OR account_type!=‘u’ OR account_status=‘A’) ORDER BY #CDUDisPort ASC,org_name ASC,n_family ASC,n_given ASC
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘’ at line 1 (1064)
-> this looks like it’s related to my custom-defined ‘extra’ tab fields… (#CDUDisPort is the name of one of them)
in the Resources, all the custom/extra tab fields I’ve had set up, are gone
(they included some javascript snippets)
(I’ve not checked on the database itself yet, whether the content is still there)
while the infolog ‘replies’ to the ‘tickets’ are shown ‘tree-like’,
as I always longed they would be, they are also shown above the parent
(in other words, infolog shows them twice : once ‘above’ the ticket,
and second time under and to the right; IMHO only the latter should be shown.)
(I can’t seem to find what template am I using on it right now
nor a switch to change it to another one to check)
in Resources, the category drop-down lists the global categories allowed to it, all mixed up
(infolog however displays them right) - categories that should be in the same group,
(from same parent category) are sometimes displayed way beyond the point they should be,
often belonging to different parent than they should be.
Hope this helps,
Kind Regards,
Lukasz
Open source business process management suite built on Java and Eclipse
Turn processes into business applications with Bonita BPM Community Edition
Quickly connect people, data, and systems into organized workflows
Winner of BOSSIE, CODIE, OW2 and Gartner awards
http://p.sf.net/sfu/Bonitasoft
