hello
EGW can be modified and expanded - you can also remove from view any of the modules you dont plan to use.
We have successfully leveraged EGW for inventory & equipment sign-out. I am trying to push for greater use of the resource module for conference management (like a hotel). There is an easy-to-use panel for adding custom fields in the resource manager and other modules.
You might not get a lot of response from the EGW team on this list for a while. They are very busy with finalizing the latest release.
Since EGW is built on top of MySQL or PostgreSQL, you can build extra tables and fields, and use php to interact.
Ken
regards
