Beim Klick auf den Reiter “Home” folgen diese Meldungen:
SyntaxError: expected expression, got '<' home:1:0
"Loaded data" Object { etemplate_exec_id: "home_CapTwoAdmin_554b2caa0edc20.339…", content: Object, sel_options: Array[0], readonlys: Array[0], modifications: Object, validation_errors: Array[0], langRequire: Array[12], currentapp: "home" } min:2656:2
Loading %s into home.index #home-index min:2435
"Did not load 'home' JS object" min:2658:2
"Loaded data" Object { etemplate_exec_id: "home_CapTwoAdmin_554b2caabe5b37.023…", content: Object, sel_options: Array[0], readonlys: Object, modifications: Object, validation_errors: Array[0], langRequire: Array[12], currentapp: "home" } min:2656:2
Loading %s into home.note #portlet_setup142t min:2435
"Loaded data" Object { etemplate_exec_id: "home_CapTwoAdmin_554b2caac611d6.015…", app_header: null, content: Object, sel_options: Array[0], readonlys: Array[0], modifications: Object, validation_errors: Array[0], langRequire: Array[12], currentapp: "calendar" } min:2656:2
Loading %s into home.legacy #portlet_setup142w min:2435
"Loaded data" Object { etemplate_exec_id: "home_CapTwoAdmin_554b2caaeaff29.861…", app_header: null, content: Object, sel_options: Object, readonlys: Array[0], modifications: Object, validation_errors: Array[0], langRequire: Array[12], currentapp: "news_admin" } min:2656:2
Loading %s into home.favorite #portlet_setup142n min:2435
SyntaxError: expected expression, got '<' calendar:1:0
SyntaxError: expected expression, got '<' news_admin:1:0
Object { attributes: Object, createNamespace: true, init: classExtend/prototype[name]</<(), loadFromXML: classExtend/prototype[name]</<(), getDetachedAttributes: et2_box<.getDetachedAttributes(), getDetachedNodes: et2_box<.getDetachedNodes(), setDetachedAttributes: et2_box<.setDetachedAttributes(), _ifacefuncs: Array[5], constructor: Class() } "Attribute 'options' does not exist in vbox!" min:2658:2
Object { attributes: Object, init: classExtend/prototype[name]</<(), loadContent: et2_html<.loadContent(), set_value: et2_html<.set_value(), getDetachedAttributes: et2_html<.getDetachedAttributes(), getDetachedNodes: et2_html<.getDetachedNodes(), setDetachedAttributes: et2_html<.setDetachedAttributes(), _ifacefuncs: Array[5], constructor: Class() } "Attribute 'options' does not exist in html!" min:2658:2
"Changing nextmatch filters to " Object { col_filter: Object, filter: "3", filter2: "content", search: "" } min:2656:2
Diese Website verwendet ein SHA-1-Zertifikat; es wird empfohlen, Zertifikate mit Signaturalgorithmen zu verwenden, die stärkere Hashfunktionen verwenden als SHA-1.[Weitere Informationen] sddefault.jpg
Diese Website verwendet ein SHA-1-Zertifikat; es wird empfohlen, Zertifikate mit Signaturalgorithmen zu verwenden, die stärkere Hashfunktionen verwenden als SHA-1.[Weitere Informationen] hqdefault.jpg
