“Cornelius Weiss” egw@von-und-zu-weiss.de schrieb:
So i think i better spend my time and take a look into a json interface.
There the Ext.data.JsonReader fits perfectly and as php6 will have
native json parsers this is the way to go anyway.
PHP5.2 already has the native JSON parser included by default. For 5.1 the
parser is available as PECL extension.
I already implemented a basic json concept for the proposal. I’ll try to
document it over the day. I will also make the source code available after
i have removed some ugly debug statements.
Also have a look at Ext.data.JsonStore. It makes the setup a little bit
easier.
Lars Kneschke
Metaways Infosystems GmbH
Pickhuben 2-4, D-20457
Hamburg
eGroupWare Support:
http://www.egroupware-support.net
OfficeSpot.Net Collaboration Server:
http://cs.officespot.net
Web:
http://www.metaways.de
Tel: +49 (0)40 317031-21
Fax: +49 (0)40
317031-921
Mobile: +49 (0)175 9304324
Metaways Infosystems GmbH - Sitz:
D-22967 Tremsbüttel
Handelsregister: Amtsgericht Ahrensburg HRB
4508
