Hello everyone,
we have released a new maintenance and SECURITY relaease 26.2.20260224.
Release notes:
- SECURITY and maintenance release: everyone is strongly adviced to update to this release, or 23.1.20260224
- Addressbook: do not disable contact edit button in CRM view
- Api: fix printing
- Api: remove “Remember and do not ask again” checkbox for adding new entries(e.g. mail addresses) to a popup
- Api: fix Number & Url webComponents did not fully validate server-side
- Api: entering “none” as the link, the logo points to, disables the link
- Api: fix re-opening an application did not send the menu data
- Api: fix implicit sort preference was no longer applied
- Mail: show either the time for today or the date with a time-tooltip, also show the date with only a 2-digit year
- Invoices: fix SQL error (Illegal mix of collations) when searching / entering a position with a non-ascii character (like a German umlaut)
- RAG: fix wrong condition causing only deleted calendar entries to be indexed
- Timesheet: timesheet showed wrong time (minutes) when stopping the project-specific timer
- Tracker: fix lists of ticket is empty after new login under some conditions
- AD/LDAP Import: new option to write changes made in EGroupware back to AD/LDAP (disabled by default)
This time only fixes and small UI improvements
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
