Hello everyone,
we have released a new maintenance and Security relaease 26.10.20261021.
As stated here
Serious security vulnerability in PHP, update required - customer information 21.10.2026
Schwerwiegende Sicherheitslücke im PHP, Update erforderlich - Kundeninfo 21.10.2026
several security vulnerabilities in PHP need to be patched as a matter of urgency.
We have made a container updated to PHP 8.5.12 available. The container should be installed immediately!
Manual installation:
cd /etc/egroupware-docker
docker compose pull && docker compose up -d && docker logs -f egroupware
# Press Ctrl-C to exit once you see: NOTICE: fpm is running, pid 1
Otherwise, the container will be installed tonight as part of a standard installation.
Please ensure you check that PHP 8.5.12 is being used. Simply access the PHP info in the admin area…
Package updates should also be carried out on the host. This includes package updates for EGroupware.
Release notes:
- SECURITY: PHP 8.5.12 security update plus one EGroupware security update, everyone is strongly advised to update to this release!
- Admin: fix not working “Open”/“Copy”/“Add” row actions after security update
- Calendar: an subscribed iCal feed without ETag is synced at most once an hour, whatever interval the user chose
- Mail: configured Sent folder was not used, nor the selected folder in compose
- Mail: a genuinely one-page email no longer prints onto two pages in Chrome
- Mail/all apps: compose or edit dialogs no longer stay open after a successful send/save on mobile
This Maintenance update is provided via Docker container an Packages.
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
