Hello everyone,
we have released a new maintenance and SECURITY relaease 26.5.20260507.
This update also includes maintenance update 26.5.20260506.
Release notes:
26.5.20260507
- SECURITY and maintenance release: everyone is strongly adviced to update to this release
- Api: fix customfields on tabs were excluded from filters
- Api: Initial application load UI improvements
26.5.20260506
- Api: change legacy search by multiple words to be ordered by number of matches (“A B” --> returns matches containing A and B first)
- Calendar/CalDAV: fix diverse problems with accidentally introduced DateTime objects / wrong timezone in the sync
- Calendar/InfoLog/REST-API: implement a time-range filter with start- and end-date for Calendar and InfoLog
- Mail: sending a mail now respects the preference preset for smime_sign and smime_encrypt
- Invoices: new filter for incoming, outgoing or all invoices (vs. offers or order confirmations)
- Invoices: many bug-fixes for the REST APi
- RAG: fix specifying apps in the config lead to an error as the plugin was not found
This is a security update! It should be installed immediately, and/or you should check that it has been installed automatically.
If you search the address book (using Legacy Search) for Hans Müller, for example, the results containing both Hans and Müller appear first, followed by those containing either one.
See:
https://your.domain.tld/egroupware/doc/openapi/
It is now possible to sort invoices by incoming, outgoing (and all) invoices:
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
