Hello everyone,
we have released a new maintenance and Security relaease 26.7.20260724.
Release notes:
- SECURITY: this release fixes multiple security vulnerabilities, everyone is strongly adviced to update to it!
- Admin: fix lost background image, if config from apps like calendar or addressbook is saved
- Adressbook/other apps: fix merge-print with converting to PDF failed after last security release
- Auth/OpenIDConnect: only use unverified email, if explicitly enabled in configuration
- ImportExport: fix stalled installation caused by last security hardening
- ProjectManager: fix SQL error when searching in element list for 2 or more keywords
This update is also a security update!
Please be sure to check whether the automatic update worked, or trigger it manually if necessary or desired.
You can find the version here:
https://help.egroupware.org/t/where-can-i-find-the-egroupware-version-number/79853
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
