Hello everyone,
we have released a new maintenance and Security relaease 26.8.20260811.
Release notes:
- SECURITY: this release fixes multiple high level security vulnerabilities, everyone is strongly adviced to update to it!
- Admin: fix TypeError in clearing openid access-tokens on password reset
- Auth: fix TypeError authenticating with OAuth Bearer token / id_token cookie
- Calendar: fix TypeError when importing iCal, one more date not being a DateTime
- Calendar: make sure notifications are in user timezone
- OpenID: diverse fixes / regressions after the update in the last release
- WebAuthN: fixed existing passkeys were not longer working due to missing proxy configuration
This update is also a security update!
Please be sure to check whether the automatic update worked, or trigger it manually if necessary or desired.
You can find the version here:
https://help.egroupware.org/t/where-can-i-find-the-egroupware-version-number/79853
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
