Hello everyone,
we have released a new maintenance and Security relaease 26.8.20260819.
Release notes:
- SECURITY: this release fixes multiple high level security vulnerabilities, everyone is strongly adviced to update to it!
- Mail: add S/MIME CSR export/import and self-signed certificate generation
- Mail: S/MIME .cer/PKCS#7 upload support, intermediate CA cert, passphrase UX
- Mail: fix folder-management delete confirmation opening in the wrong window
- Import/Export: fix definitions with a link filter with app but no entry would limit to 0 results
This update is also a security update!
Please be sure to check whether the automatic update worked, or trigger it manually if necessary or desired.
You can find the version here:
https://help.egroupware.org/t/where-can-i-find-the-egroupware-version-number/79853
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
