Hello everyone,
we have released a new maintenance relaease 23.1.20250902.
Release notes:
- Mail: fixed Sieve vacation notice could not be set by admin for an other user
- Calendar/REST API: fixed the locations object was not parsed
- InfoLog/REST API: return all entries the user has access to for /infolog, not just his own ones, also fix not working search
- InfoLog/REST API: do NOT add default type-filter of “task” for REST API
- REST API: fix empty/0 byte uploads through /links/ collection
- REST API: fix PUT and POST requests to /links/ collection to upload files were wrongly denied (due to their content-type)
- Filemanager: jobs to monitore directories and create InfoLog entries from files in it
- Many translations
Complete changelog:
https://github.com/EGroupware/egroupware/compare/23.1.20250715…23.1.20250902
It is now possible to monitor folders in the file manager and trigger jobs when file changes are made.
For the moment there are jobs for InfoLog. This can be expanded according to customer requirements.
This means that an InfoLog can be created automatically and the file can be moved:
For example, documents scanned into a directory can be converted directly into a task and assigned. This could become an invoice workflow. Or whatever ![]()
in chronological order.
Kind regards
Your EGroupware team
