Hello everyone,
we have released a new maintenance relaease 26.2.20260216.
Release notes:
- API: fix context menu copy used the whole row instead of the target widget
- Addressbook: restyle crm-view sidebox and fix postcode size
- CRM: fix search did not change filter
- Filemanager: fix uploads on mobile did not always open file selection
- Filemanager: file list lost the current path after submitting
- Filemanager: fix 2 favourites with different paths could lose current path
- Mail: restyling of the mail list.
- Invoices: fix error Unsupported operand types: array + float when copying an invoice
- Projectmanager: fix missing link app in element list toolbar’s add element
- Projectmanager: fix print view description row
- Projectmanager: fix projectelement dialog sizing blocked footer buttons
- RAG: new preference defaulting addressbook search to legacy and fix deleting from RAG indexes
- RAG: fulltext index only returns matches with at least 5% of the relevance of the top match
- RAG: stay with fulltext search in NATURAL LANGUAGE MODE, if pattern ends with a dash
- RAG: fix wrongly namespaced InvalidSQL exception causing deletes to fail, if egw_rag table is not installed
- RAG/Backup: dimensions of vector / embeddings were not backed up and therefore restore failed
- Resources: setting group-owners on resource categories no longer limit the visibility of them and their resources, only the ACL does
- Status: scrolling did not work
It is now possible to set the search mode for the address book search differently from the general setting (below).
The full-text search now only returns hits with at least 5% relevance.
Kind regards
Your EGroupware team
