Hello everyone,
we have released a new maintenance relaease 26.3.20260316.
Release notes:
- Admin: Fix categories Add button & placeholder (“No matches found”) context menu add
- Api: Fix popup resize did not make popups larger
- Api: Fix customfields field filtering was still creating DOM nodes in some cases
- Api: Fix widgets with validation errors could require scrolling to find them
- Api: Fix multiple anonymous shares could conflict with the last opened blocking the earlier ones
- Api: Include translations when searching in local select options
- Api: Allow application entry customfields into the filter drawer
- Api: Avoid type error from edit group command if old value is not an array
- Api: Fix printing large lists could cut off the last rows
- Calendar: fix highlighting of active favorite
- Calendar: delete unnecessary rows for timezone and participants, accounting for a huge amount of the history-log
- Calendar: Fix actions did not get fully cleaned up on destroy
- Mail: fix downloading attachment for mail on mobile
- InfoLog: Fix context menu action ‘close’ did not close entry
- InfoLog: Allow customfields to be configured as editable by responsible users as well
- InfoLog: was ignoring the search-type set in the filterbox and always use fulltext by default
- Invoices: add construction invoice types
- Invoices: position level surcharges or discounts incl. new placeholder {{PositionAllowances}}
- Invoices: document level surcharges and discounts
- Invoices: separate config to allow arbitrary invoice dates (off by default)
- kDots: fix open-tabs or active-tab preference to show “Users choice” as placeholder and not extra value
- Timesheet: timesheet showed wrong time (minutes) when stopping the project-specific timer
- ViDoTeach: Fix Add & edit material -> Live feedback session gave error
Only bug fixes, except:
Kind regards
Your EGroupware team
