Hello everyone,
we have released a new maintenance relaease 26.4.20260424 (including 26.4.20260423).
Release notes:
26.4.20260424
- Calendar/CalDAV: fix regression causing CalDAV updates of recurrences to fail
- AiTools: fix not working new installation
26.4.20260423
- AiTools: allow admins to define user- and app-specific custom prompts
- Addressbook/REST-API: fix not logged GET requests and ignore limit from user preference what to sync
- Admin: fix DB backup & restore to create fulltext index for egw_rag_fulltext
- AD/LDAP/Import: fix not renamed home-directory, if user-name was changed in AD/LDAP
- Api: show scrollbar in Log windows
- Api: Fix cancelled file upload could not upload the same file again
- Api: Always show all applicable customfield filters
- Api: client-side performance improvments for loading lists in all apps specially initally or after a reload
- Api: Server-side initial load speed improvements
- InfoLog: Fix add in CRM view lost the contact ID after a reload
- Invoices: use Collabora to convert first page(!) of PDFs with just paths (no text or scanned images) to an image to import
- Mail: support filtering mime handlers to app-specific only in attachments
- Mail: do NOT show meeting request UI for attached ICS files (only for meeting requests)
- Mail/REST-API: stick to the identity set in the compose call (ignore the user preference)
- OpenID: allow to specify iframe allow values as scopes to allow managed app’s access to microphone or clipboard e.g. Open WebUI
- OpenWebUI: planed to be used as AI assistent see installations instructions
- OpenWebUI: allow to use EGroupware REST-API with OpenAPI description as tools for OpenWebUI
Administrators can now define their own prompts. A configuration screen is now available for this purpose:
Under no circumstances should the default prompts be deleted or modified.
However, the default prompts can be disabled, and user permissions and apps can be configured. The order of the AI Tools menu can also be customized:
You can freely create your own new prompts:
It is now possible to use Collabora Online (the first page) to convert a (standard) PDF invoice into an image and then import it into the invoicing app using AI.
It is now possible to configure iframe values as sections in the client configuration to grant managed apps access to the microphone or clipboard. For example, Open WebUI: “Iframe microphone” allows Open WebUI to access the microphone within the Iframe.
Open WebUI is designed to serve as an AI assistant for EGroupware. Installation instructions can be found here:
https://github.com/EGroupware/openwebui/tree/main
- OpenWebUI: allow to use EGroupware REST-API with OpenAPI description as tools for Open WebUI
It is now possible to make the EGroupware REST API (via OpenAPI documentation under https:/your.egwdomain.tld/egroupware/doc/openapi/ ) available for use in Open WebUI.
Kind regards
Your EGroupware team
