Hello everyone,
we have released a new maintenance relaease 26.7.20260702.
Release notes:
- Calendar/CalDAV/REST: wrong etag returned in CalDAV REPORT/PROPFIND or REST PUT/PATCH causing event updates being rejected
- Calendar/CalDAV: fix deleting of recurrances/parsing EXDATE
- Calendar/CalDAV: fix broken sync-token causing all events being synced / high server load
- Calendar/ActiveSync: using now automatic conversation from DateTime objects from our own z-push 2.5.0.2
- Mail: do not try to load Preview if no mail is selected
- Mail: prevent attempt to delete when no mail is selected
- OpenID: fix error (Class “League\OAuth2\Server\RequestTypes\AuthorizationRequest” not found) when confirming scopes
- PHP: fix 3 more usages of PHP 8.4+ syntax while requiring only PHP 8.2 (we recommend PHP 8.5!)
This time only fixes!
Please follow us, give us likes or stars:
Kind regards
Your EGroupware team
