Hi Jörg,
thank you very much for your fast reply! I am happy to test your new patch (20090515-3) in my environment.
First of all I want to say that the patch works really great, I just applied it to our production server
More details:
contacts (./contacts):
– windows movile client with funambol
- Added contact to wm6.1 device, sync with funambol 6.5.18: works
- Added contact to egroupware, sync with funambol 6.5.18: works
- Modified contact on wm6.1 device, sync with funambol 6.5.18: works
- Modified contact on egroupware, sync with funambol 6.5.18: works
- Deleted contact on wm6.1 device, sync with funambol 6.5.18: works
- Deleted contact on egroupware, sync with funambol 6.5.18: works
- Added new contact with email to egroupware, sync with funambol 6.5.18 -> email showes up on “E-Mail3” on wm6.1 device (no problem nevertheless…)
– thunderbird / lightning with funambol mozilla sync client 0.9.1
- Added contact to thunderbird, sync with funambol client 0.9.1: works (but needed some syncs…)
- Added contact to egroupware, sync with funambol client 0.9.1: works
- Modified contact on thunderbird, sync with funambol client 0.9.1: works
- Modified contact on egroupware, ssync with funambol client 0.9.1: works
- Deleted contact on thunderbird, sync with funambol client 0.9.1: works
- Deleted contact on egroupware, sync with funambol client 0.9.1: works
calendar (./calendar):
- Added event to wm6.1 device, sync with funambol 6.5.18: works
- Added event to egroupware, sync with funambol 6.5.18: works
- Modified event on wm6.1 device, sync with funambol 6.5.18: works
- Modified event on egroupware, sync with funambol 6.5.18: works
- Deleted event on wm6.1 device, sync with funambol 6.5.18: works
- Deleted event on egroupware, sync with funambol 6.5.18: works
–> Adressbook on thunderbird must be closed on reopened to show modifications (at least sometimes)
tasks (./tasks):
- Added taks to wm6.1 device (status “not started”), sync with funambol 6.5.18: syncs but has status “done”
- Added task to egroupware, sync with funambol 6.5.18: does NOT show up on wm6.1 device
- Modified the task which was added on wm6.1 device on egroupware, sync with funambol 6.5.18: description is synced, status is not synced
- Deleted task task which was added on wm6.1 device on egroupware, sync with funambol 6.5.18: works (task is deleted on wm6.1 device as well)
- Added taks to thuderbird (status “no status”), sync with funambol: syncs, has status “not started”
- Added task to egroupware (status “not started”, sync with funambol: syncs, has status “needes attention”
- Moified task in thunderbird (-> status “in work”), sync with funabol: works
- Moified task in egroupware (-> status “in work”), sync with funabol: works
- Delete task in thunderbird (-> status “in work”), sync with funabol: works
- Delete task in egroupware (-> status “in work”), sync with funabol: works
I translated the status desctiption to english, thry may not be exact.
Unless tasks everithing seems to work
We will use the patch now, and let you know if we find some issues.
Thanks again for this great patch and let me know if i should test something!
Stephan
