Werner Mohren mohren@orn.mpg.de schrieb:
is there any reason, why syncml should not work over proxy (
egroupware-server is internal )?
Actually it works from inside, but not from outside.
Should ports apart from 80 be open?
If you use the lastest stable version it should work. But to be sure make
sure you update also from svn(1.2 branch).
