Sorry, but how can I “specify a high number for ip, if all user come
over a proxy or nat gateway, to not block that” ?
That’s meant literally, if all users come over a proxy or nat gateway,
specify a high number for the ip address check and a lower per user
number. Then a user gets blocked via his username and not the ip.
Thanks for your help!
Luca
<tolomelli.luca@gmail.com <mailto:tolomelli.luca@gmail.com>>:
> Is it possible in EGW 1.6 never block a login attempt if it comes
from within a specific IP range (i.e. our LAN)?
No, you can only specify different numbers per user or ip address.
Eg. specify a high number for ip, if all user come over a proxy or
nat gateway, to not block that.
[ open style of IT ]
Morschheimer Strasse 15
D - 67292 Kirchheimbolanden
fon +49 (6352) 70629-0 <tel:%2B49%20%286352%29%2070629-0>
fax +49 (6352) 70629-30 <tel:%2B49%20%286352%29%2070629-30>
mobil +49 (170) 3147833 <tel:%2B49%20%28170%29%20%203147833>
email rb@stylite.de <mailto:rb@stylite.de>
www.stylite.de <http://www.stylite.de>
www.egroupware.org <http://www.egroupware.org>
Geschäftsführer: Andre Keller,
Registergericht Kaiserslautern, HRB 30575
Fulfilling the Lean Software Promise
Lean software platforms are now widely adopted and the benefits have
been
demonstrated beyond question. Learn why your peers are replacing JEE
containers with lightweight application servers - and what you can gain
from the move. http://p.sf.net/sfu/vmware-sfemails
_______________________________________________
<mailto:eGroupWare-users@lists.sourceforge.net>
Lean software platforms are now widely adopted and the benefits have been
[open style of IT]
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller, Ralf Becker
