I’m using debian jessie.
I’m trying to export contacts in VCard format from my EGW 1.8 installation,
leading to ‘file not found’ error page.
Looking at apache log i see:
[Fri Sep 11 11:05:59.904449 2015] [:error] [pid 19903] [client 88.37.116.142:35894] PHP Warning: require_once(Horde/Browser.php): failed to open stream: No such file or directory in /usr/local/share/egroupware/phpgwapi/inc/horde/Horde/NLS.php on line 228, referer: https://egw.lilliput.linux.it/index.php?menuaction=addressbook.addressbook_ui.index
[Fri Sep 11 11:05:59.904541 2015] [:error] [pid 19903] [client 88.37.116.142:35894] PHP Fatal error: require_once(): Failed opening required ‘Horde/Browser.php’ (include_path=’/usr/local/share/egroupware/egw-pear:.:/etc/egroupware:/usr/share/php/’) in /usr/local/share/egroupware/phpgwapi/inc/horde/Horde/NLS.php on line 228, referer: https://egw.lilliput.linux.it/index.php?menuaction=addressbook.addressbook_ui.index
so, after that i’ve installed the debian package ‘php-horde-browser’,
restarted apache (to make sure there’s no cache trouble) and after
that page still does not work, but error now is:
[Fri Sep 11 11:15:02.044852 2015] [:error] [pid 27724] [client 88.37.116.142:37157] PHP Fatal error: Class ‘Browser’ not found in /usr/local/share/egroupware/phpgwapi/inc/horde/Horde/NLS.php on line 229, referer: https://egw.lilliput.linux.it/index.php?menuaction=addressbook.addressbook_ui.index
What i’m missing? Thanks.
Sicuramente non è necessario essere laureati in economia e commercio
per scrivere cazzate, ma aiuta. (MdI)
