Hi Ralf
I tried today evening this (on CentOS8):
# wget https://download.docker.com/linux/centos/docker-ce.repo -O /etc/yum.repos.d/docker-ce.repo
# wget https://download.opensuse.org/repositories/server:eGroupWare/CentOS_8/server:eGroupWare.repo -O /etc/yum.repos.d/eGroupWare.repo
Then i tried to install eGroupware by using this command:
# yum install egroupware-docker egroupware-collabora-key egroupware-rocketchat
The result was this:
[root@mail ~]# yum install egroupware-docker egroupware-collabora-key egroupware-rocketchat -y
Last metadata expiration check: 0:00:18 ago on Mon 07 Oct 2019 08:29:21 PM CEST.
Error:
Problem 1: package docker-compose-1.24.1-6.1.x86_64 requires docker-ce >= 18.06.1, but none of the providers can be installed
- package podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch conflicts with docker-ce provided by docker-ce-18.06.1.ce-3.el7.x86_64
- package docker-ce-18.06.1.ce-3.el7.x86_64 conflicts with docker provided by podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch
- package podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch conflicts with docker-ce provided by docker-ce-18.06.2.ce-3.el7.x86_64
- package docker-ce-18.06.2.ce-3.el7.x86_64 conflicts with docker provided by podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch
- package podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch conflicts with docker-ce provided by docker-ce-18.06.3.ce-3.el7.x86_64
- package docker-ce-18.06.3.ce-3.el7.x86_64 conflicts with docker provided by podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch
- package podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch conflicts with docker-ce provided by docker-ce-3:18.09.0-3.el7.x86_64
- package docker-ce-3:18.09.0-3.el7.x86_64 conflicts with docker provided by podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch
- package podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch conflicts with docker-ce provided by docker-ce-3:18.09.1-3.el7.x86_64
- package docker-ce-3:18.09.1-3.el7.x86_64 conflicts with docker provided by podman-docker-1.0.0-2.git921f98f.module_el8.0.0+58+91b614e7.noarch
- package egroupware-collabora-key-1.3.20190911-2.1.noarch requires docker >= 1.12, but none of the providers can be installed
- package egroupware-docker-19.1.20190917-9.1.noarch requires docker-compose >= 1.10.0, but none of the providers can be installed
- package docker-ce-3:18.09.2-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.3-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.4-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.5-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.6-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.7-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.8-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:18.09.9-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:19.03.0-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:19.03.1-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- package docker-ce-3:19.03.2-3.el7.x86_64 requires containerd.io >= 1.2.2-3, but none of the providers can be installed
- conflicting requests
- package podman-docker-1.0.0-2.git921f98f.module_el8.0.0+57+bb81156c.noarch is excluded
- package containerd.io-1.2.2-3.3.el7.x86_64 is excluded
- package containerd.io-1.2.2-3.el7.x86_64 is excluded
- package containerd.io-1.2.4-3.1.el7.x86_64 is excluded
- package containerd.io-1.2.5-3.1.el7.x86_64 is excluded
- package containerd.io-1.2.6-3.3.el7.x86_64 is excluded
Problem 2: package docker-compose-1.24.1-6.1.x86_64 requires docker-ce >= 18.06.1, but none of the providers can be installed
- package egroupware-rocketchat-1.3.20190822-1.1.noarch requires docker-compose, but none of the providers can be installed
- package egroupware-rocketchat-1.3.20190822-1.1.noarch requires docker >= 1.12, but none of the providers can be installed
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
In case i try the same without the docker-ce.repo, i get this:
# mv /etc/yum.repos.d/docker-ce.repo /etc/yum.repos.d/docker-ce.xxx
Last metadata expiration check: 0:10:11 ago on Mon 07 Oct 2019 08:25:39 PM CEST.
Error:
Problem 1: conflicting requests
- nothing provides docker-ce >= 1.12 needed by egroupware-docker-19.1.20190917-9.1.noarch
Problem 2: package egroupware-rocketchat-1.3.20190822-1.1.noarch requires docker-compose, but none of the providers can be installed
- nothing provides docker-ce >= 18.06.1 needed by docker-compose-1.24.1-6.1.x86_64
Problem 3: package egroupware-collabora-key-1.3.20190911-2.1.noarch requires docker-compose, but none of the providers can be installed
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
I’m not sure if we used the same repo for eGw.
