Hi Robert,
the server answered 201 AND send a Location header with the id/path of
the new entry:
case ‘PUT’:
if (($ok = $handler->check_perms(EGW_ACL_EDIT,$id)) === false)
error_log(“icalsrv_groupdav::_addressbook_get_put_delete($method,$id)
403 Forbidden: check_perms(EGW_ACL_EDIT,$id)==false”);
return ‘403 Forbidden’;
$contact = $handler->vcardtoegw($options[‘content’]);
if (!is_null($ok)) $contact[‘id’] = $id;
if (!$handler->save($contact)) return false;
header('ETag: "'.$contact['id'].':'.$contact['modified'].'"');
if (is_null($ok))
header($h'Location: '.$this->base_uri.'/addressbook/'.$contact['id']);
header(’$h’): 201 Created”);
return ‘201 Created’;
return true;
Robert Bolduc schrieb:
Hi Ralph,
For a successful PUT operation the correct response is supposed to be
201. It seems the server is responding 403 (forbidden). Is there a
reason for that response code?
The 403 in the logfile of the guy on the user list, might be from an
older version of the addressbook, in which check_perm() returns false
for both: a non-existing entry and if you have no permission.
This log is from my own development box. It differs only in the
additional error_log statement for the successful adding of the entry:
[Sat Oct 20 07:44:05 2007] [error] [client 127.0.0.1]
icalsrv_groupdav::PROPFIND(Array\n(\n [path] => /addressbook/\n
[depth] => infinity\n [props] => all\n)\n)
icalsrv_groupdav::PROPFIND: user=, app=‘addressbook’, rest=
[Sat Oct 20 07:44:06 2007] [error] [client 127.0.0.1]
icalsrv_groupdav::PUT(Array\n(\n [path] =>
/addressbook/AA-7ec9cac4-b9f7-f01a-8e\n [content_length] => 206\n
[content_type] => text/x-vcard; charset=UTF-8\n [stream] => Resource
id #91\n [content] =>
BEGIN:VCARD\r\nVERSION:3.0\r\nUID:AA-7ec9cac4-b9f7-f01a-8e\r\nN:Nachbird;Vorthunder\r\nFN:Vorthunder
Nachbird\r\nNICKNAME:email\r\nADR;TYPE=work:;;;;;;\r\nADR;TYPE=home:;;;;;;\r\nEMAIL;TYPE=work:group@dav.de\r\nEND:VCARD\r\n\r\n\n)\n),
referer:
http://localhost/egroupware/icalsrv/groupdav.php/addressbook/AA-7ec9cac4-b9f7-f01a-8e
icalsrv_groupdav::_addressbook_get_put_delete(PUT,AA-7ec9cac4-b9f7-f01a-8e)
header(‘Location:
http://localhost/egroupware/icalsrv/groupdav.php/addressbook/1620’): 201
Created, referer:
The entry is shown then in Thunderbird, but it failed to recognice the
new location, as you can see when I hit the Sync button direct after:
[Sat Oct 20 07:44:50 2007] [error] [client 127.0.0.1]
Thunderbird requests the new entry via GET:
icalsrv_groupdav::GET(Array\n(\n [path] => /addressbook/1620\n)\n)
And now I have 2 new entries with the same content, thought I cant
delete the one with the wrong id, as it does not exist on the server.
Anyway thanks for the nice plugin and helping debuging the GroupDAV code
Telefon +49 (0)631 31657-0
