Hi Nathan,
you can start using it NOW
My plans to replace the regular db access with PDO, will still allow to
use that syntax.
Please remember you need to specify the application ($app param of
select), if it’s not the api AND you can’t do
$GLOBALS[‘egw’]->db->set_app(‘myapp’) as that will break the api.
Nathan Gray schrieb:
To be clear about these (r25021) changes:
Old: ($db is clone of $GLOBALS[‘egw’]->db)
$db->select(‘table’, array(’*’), array(), LINE,FILE,…);
$list = array();
while($row = $db->row(true)) {
$row[‘date’] = $db->from_timestamp($row[‘date’]);
$list[] = $row;
return $list;
New: ($db is $GLOBALS[‘egw’]->db)
$list = $db->select(‘table’, array(’*’), array(), LINE,
FILE, …);
foreach($list as &$row) {
return $list;
How long do you think I should wait before starting to use the new way?
Nathan Gray
nathan at goarctic dot com
Telefon +49 (0)631 31657-0
