Hi Oscar,
I have several systems with a that setup, but none I can give you access
too
Here’s a rough description, maybe you can document that in our wiki.
- you need to get EGw working with LDAP, as described in phpgwapi/doc/ldap.
You can either choose the recommended qmailuser.schema from
emailadmin/doc (you have to comment out mailReplyText on most distros)
or you use the intOrgPerson schema (is more limited and not further
described).
It’s important for a multidomain setup that EGroupware domain names
match the real domain names, which are as o=domain.com,dc=something in LDAP.
- setup SASL to use LDAP via /etc/saslauthd.conf:
ldap_servers: ldap://127.0.0.1/
ldap_search_base: dc=egroupware
ldap_auth_method: bind
ldap_filter: (&(mail=%u@%d)(accountStatus=active))
ldap_debug: 1
ldap_version: 3
- configure postfix to use LDAP via /etc/postfix/main.cf:
virtual_transport = lmtp:unix:/var/lib/imap/socket/lmtp
virtual_mailbox_domains = ldap:/etc/postfix/virtual_mailbox_domains.cf
virtual_mailbox_maps = ldap:/etc/postfix/ldap-aliases.cf
virtual_alias_maps = ldap:/etc/postfix/ldap-aliases-forward-also.cf
/etc/postfix/virtual_mailbox_domains.cf:
server_host = localhost
server_port = 389
search_base = dc=egroupware
query_filter = (o=%s)
result_attribute = o
bind = no
version = 3
/etc/postfix/ldap-aliases.cf:
server_port = 389
search_base = o=%d,dc=egroupware
query_filter =
(&(accountStatus=active)(|(mail=%s)(mailAlternateAddress=%s)))
result_attribute = mail
bind = no
version = 3
/etc/postfix/ldap-aliases-forward-also.cf:
server_port = 389
query_filter =
result_attribute = mailForwardingAddress,mail
bind = no
version = 3
- configure your egroupware instances with emailadmin to use Postfix
with qmailuser schema and Cyrus.
That’s all
Oscar van Eijk schrieb:
Hi all,
I’m running into all kinda troubles trying to setup a virtual hosting
environment with eGW.
Main goal is to have single login for eGW and Cyrus. This failed with
Dovecot, but Ralf suggested Cyrus, which also requires LDAP to work.
Problem is, I can’t find any good documentation on setting up such
environment using Cyrus, LDAP, SASL and (?) PAM (in fact I’m completely
new to Cyrus which doesn’t really help…)
Does anybody have experience in this and is willing to give me some
useful pointers?
TIA,
Oscar
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Nigel Vickers und Ralf Becker
