Hi Ruud,
egw-pear was always disabled according to your database.
So I think you or a group you are a member off, had run rights for
egw-pear. Can you check that:
SELECT * FROM egw_acl WHERE acl_appname=‘egw-pear’ and acl_location=‘run’
Removing the application also removes all acl entries from it.
Hi Ralph,
that did the trick, thanks for solving this.
please find below the result from the query (run before / after
disabling application),
thanks,
Ruud.
SQL result BEFORE
Host: localhost
Database: egroupware
Generation Time: Sep 22, 2010 at 12:05 PM
Generated by: phpMyAdmin 3.2.3 / MySQL 5.0.77
SQL query: SELECT * from egw_applications WHERE app_name='egw-pear’
LIMIT 0, 30 ;
Rows: 1
app_id app_name app_enabled app_order app_tables app_version
app_icon app_icon_app app_index
4 egw-pear 0 99 1.8 /NULL/ /NULL/ /NULL/
SQL result AFTER
Host: localhost
Generation Time: Sep 22, 2010 at 12:12 PM
LIMIT 0, 30 ;
Rows: 1
33 egw-pear 0 99 1.8 /NULL/ /NULL/ /NULL/
From: “Ralf Becker-2 [via EGroupware]” <[hidden email]
</user/SendEmail.jtp?type=node&node=1560208&i=0>>
To: “Ruud” <[hidden email]
</user/SendEmail.jtp?type=node&node=1560208&i=1>>
Date: Wed, 22 Sep 2010 02:16:06 -0700 (PDT)
Hi Ruud,
congratulations in the release of RC 1.8.001 of egroupware.
Installed is via repo (CentOS) and already love the new look /
features.
I also found some strange things that I will post here (separate
threads to
keep a good oversight).
after installation (upgrade from 1.6.003) I now have a ‘new’ icon in my
topbar:
EGW-PEAR -> a yellow box with a question mark.
Can you run the following SQL on your DB and post the result:
SELECT * from egw_applications WHERE app_name=‘egw-pear’;
After go to setup and remove egw-pear application in manage applications
and install it again. That should fix your problem / hide egw-pear again.
pressing the icon gives me a ‘not found: The requested URL
/egroupware/egw-pear/index.php was not found on this server.’ error.
how do I get rid of this icon as I do not know what it is for and it
was
never there before?
thanks,
Ruud.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: [hidden email]
</user/SendEmail.jtp?type=node&node=1559868&i=0&by-user=t>
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
[hidden email] </user/SendEmail.jtp?type=node&node=1559868&i=1&by-user=t>
View message @
http://egroupware.219119.n3.nabble.com/egw-pear-icon-in-egw-1-8-001-tp1559677p1559868.html
http://egroupware.219119.n3.nabble.com/egw-pear-icon-in-egw-1-8-001-tp1559677p1559868.html?by-user=t
To unsubscribe from egw-pear icon? in egw 1.8.001, click here
http://egroupware.219119.n3.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=1559677&code=cnV1ZC52YW4ubGVudEB6b25uZXQubmx8MTU1OTY3N3w0MzUxMDg1MjY=&by-user=t.
View this message in context: Re: egw-pear icon? in egw 1.8.001
http://egroupware.219119.n3.nabble.com/egw-pear-icon-in-egw-1-8-001-tp1559677p1560208.html
Sent from the egroupware-developers mailing list archive
http://egroupware.219119.n3.nabble.com/egroupware-developers-f278587.html
at Nabble.com.
[open style of IT]
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
