I’ve started using the SyncML Extension to synchronize my Sony-Ericsson
P1i tasks and calendar events (caltasks) with our eGW installation
(1.6.002). This patch is needed because the phone talks SyncML 1.2 but
eGW supports only 1.1 out of the box.
Overall it seems to work quite good, but I’m facing the following
issues:
Calendar events are sometimes duplicated in eGW, but appear only
once in the phone. I’m not sure what causes this.
Tasks priorities: Urgent (eGW) is mapped to 1 (phone), high, normal
and low are all mapped to 3. I would suggest:
urgent and high 1
normal 2
low 3
high = 2 would also be ok
I would like to have an option to exclude done tasks. I want to keep
them in eGW for archiving purposes but prefer not to have them on the
phone to avoid slowing down the phone.
I deleted some tasks on the phone but they where not deleted in eGW
but instead reappeared on the phone after sync. Then I deleted them in
eGW and did another sync. Now they are gone. Does this mean deleting is
only possible on the server?
eGW settings: ‘Categories for Conflict Duplicates’ can’t be selected,
there are none in the dropdown list (only ‘Vorgabe benutzen’).
I tried to synchronize notes as well, but this does not work at all.
The phone says ‘Unbekannter Fehler’ (Unknown error).
Is there a log somewhere which would allow me to see what is going on?
To avoid additional problems caused by conflicts I do all changes only
on the phone at the moment.
I did not try to synchronize contacts / addressbook.
Thanks,
Manfred
Manfred Usselmann usselmann.m@icg-online.de
ICG IT Consulting GmbH, Kelkheim
