With the latest update, starting with version 26.0.20260108, the suggestion no longer appears when typing an email address.
To see the suggestion, you need to type the “@” as long as the first part of the address is correct.
Until the update, you only needed to type the first three characters of the name, not necessarily the exactly email address.
Is this a problem unique to me, or has this already been reported?
Example
email address = p.contarino@cortizootecnici.it
previously if I type “pie” (3 char of my name) appear email address = p.contarino@cortizootecnici.it
previously if I type “con” (3 char of my surname) appear email address
now appear only if I type “p.contarino@”
if I type alle the name (pierangelo) or surname (contarino) nothing appear.
Thanks in advance
