Hi Anthony,
Just a quick note that the recently modified emailadmin upgrade script isn’t
safe for PostgreSQL:
process->upgrade(): emailadmin(1.9.010 --> 1.9.011): running
emailadmin_upgrade1_9_010()
Invalid SQL: SELECT * FROM egw_felamimail_accounts WHERE fm_active=1 ERROR:
operator does not exist: boolean = integer LINE 1: SELECT * FROM
egw_felamimail_accounts WHERE fm_active=1 ^ HINT: No operator matches the
given name and argument type(s). You might need to add explicit type casts.
(-1)
–> 1.9.011
Update emailadmin from svn and try again. Should be fixed now.
October Webinars: Code for Performance
Free Intel webinars can help you accelerate application performance.
Explore tips for MPI, OpenMP, advanced profiling, and more. Get the most from
the latest Intel processors and coprocessors. See abstracts and register >
http://pubads.g.doubleclick.net/gampad/clk?id=60135991&iu=/4140/ostg.clktrk
