I have been using Lightning for a long time with several eGW calendars
without major problems. However, suddenly one of the calendars is
totally empty in Lightning. All events are still there in eGW as can be
confirmed on the web eGW calendar page.
The error console of Thunderbird gets the following 2 errors when I
activate the calendar:
Fel: thisCalendar is not defined
Källkodsfil:
file:///usr/lib/mozilla/extensions/%7B3550f703-e582-4d05-9a08-453d09bdfdc6%7D/%7Be2fda1a4-762b-4020-b5ad-a41df1933103%7D/modules/calUtils.jsm
file:///usr/lib/mozilla/extensions/%7B3550f703-e582-4d05-9a08-453d09bdfdc6%7D/%7Be2fda1a4-762b-4020-b5ad-a41df1933103%7D/calendar-js/calDavRequestHandlers.js
Rad: 786
Fel: [Exception… “Component returned failure code: 0x8000ffff
(NS_ERROR_UNEXPECTED) [nsISAXXMLReader.onStopRequest]” nsresult:
“0x8000ffff (NS_ERROR_UNEXPECTED)” location: “JS frame ::
:: mg_onStopRequest :: line 818” data: no]
Källkodsfil:
Rad: 818
Otherwise, there is no error message in Thunderbird, and the calendar is
not locked either, just silently totally empty.
All other calendars display fine in Lightning. I suspect that some entry
in the struggling calendar may be corrupted but have no idea where I
could correct that.
Another problem, concerning the mailing list: I was not able to log in
at www.egroupware.org/forum in order to post this issue. Every time I
try to login, I am sent back to the login page without an error message.
At the same time, it appears as if I already am logged in because I can
browse to my account properties and my previous posts. But when I try to
open a new topic, I can’t get further than to the login page. I have
confirmed that login name and password are right by using the “Forgot
password” function.
Daniel
Virtualization & Cloud Management Using Capacity Planning
Cloud computing makes use of virtualization - but cloud computing
also focuses on allowing computing to be delivered as a service.
http://www.accelacomm.com/jaw/sfnl/114/51521223/
