Liebe Mitleserinnen und Mitleser,
Seit dem letzten Update ist kein CardDAV-Zugriff mehr möglich, sondern es werden nur mehr Fehlermeldungen produziert:
[Fri Apr 24 14:46:54 2015] [error] [client 10.xxx.xxx.xxx] Database error (egw_exception_db_invalid_sql): Invalid SQL: SELECT * FROM egw_addressbook_lists WHERE
list_owner IN (-XXXX,-XXXX,XXXX) AND egw_addressbook_lists.0 ORDER BY list_owner<>XXXX,list_name\nUnknown column ‘egw_addressbook_lists.0’ in ‘where clause’ (1054)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #0 /usr/share/egroupware/phpgwapi/inc/class.egw_db.inc.php(2068): egw_db->query(‘SELECT * FROM e…’, 5
13, ‘/usr/share/egro…’, false, -1, false, 2)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #1 /usr/share/egroupware/addressbook/inc/class.addressbook_sql.inc.php(514): egw_db->select(‘egw_addres
sbook…’, ‘*’, Array, 513, ‘/usr/share/egro…’, false, ‘ORDER BY list_o…’)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #2 /usr/share/egroupware/addressbook/inc/class.addressbook_so.inc.php(1016): addressbook_sql->get_lists
(Array, NULL, ‘contact_uid’, Array)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #3 /usr/share/egroupware/addressbook/inc/class.addressbook_groupdav.inc.php(300): addressbook_so->read_
lists(Array, ‘contact_uid’, Array)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #4 /usr/share/egroupware/phpgwapi/inc/class.groupdav_handler.inc.php(878): addressbook_groupdav->propfi
nd_callback(’/warmuth/addres…’, Array, Array)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #5 /usr/share/egroupware/phpgwapi/inc/class.groupdav_handler.inc.php(901): groupdav_propfind_iterator->
next()
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #6 /usr/share/egroupware/phpgwapi/inc/HTTP/WebDAV/Server.php(793): groupdav_propfind_iterator->rewind()
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #7 /usr/share/egroupware/phpgwapi/inc/HTTP/WebDAV/Server.php(756): HTTP_WebDAV_Server->multistatus_responses(Object(groupdav_propfind_iterator), Array)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #8 /usr/share/egroupware/phpgwapi/inc/class.groupdav.inc.php(960): HTTP_WebDAV_Server->http_PROPFIND(‘REPORT’)
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #9 /usr/share/egroupware/phpgwapi/inc/HTTP/WebDAV/Server.php(306): groupdav->http_REPORT()
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #10 /usr/share/egroupware/phpgwapi/inc/class.groupdav.inc.php(1956): HTTP_WebDAV_Server->ServeRequest()
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #11 /usr/share/egroupware/groupdav.php(53): groupdav->ServeRequest()
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] #12 {main}
[Fri Apr 24 14:46:55 2015] [error] [client 10.xxx.xxx.xxx] # Instance=warmuth.at, User=warmuth, Request=REPORT https://warmuth.at/gw/groupdav.php/warmuth/addressbook/, User-agent=Mac OS X/10.10.3 (14D136) AddressBook/1579
Anmerkung: Teile der IP-Adressen, GIDs und UIDs wurden durch “X” ersetzt.
Vor dem Update hat alles bestens funktioniert.
Liebe Grüße
Michael
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
