Hi All, I ran the system check and got this error. Does anyone know what it depends on?
Hi Gabriele.
Do you have a standard (Docker) installation? Then you can ignore this test result. The tests are not relevant because everything is set up correctly with the standard installation.
HI Stefan, I confirm that I have a standard (Docker) installation. Thank you for your reply. Gabriele
