Hi.
On another server (running SuSE 9.3 with PHP5) I’m trying to use eGWOSync, but it doesn’t login correctly.
The xmlrpc features are enabled in eGroupWare and the php5-xmlrpc package is installed.
Here is the extract of the log file:
“08/02/2008@20.48.43: “
“<?xml version=""1.0"" encoding=""utf-8""?>
system.login
username
[USER]
password
[SECRET PASSWORD]
domain
default
"08/02/2008@20.48.43: “
faultCode
104
faultString
XML error: Empty document at line 1
I have no error in the Apache error log file, only the correct access in the Apache access log file:
[MY IP ADDRESS] - - [08/Feb/2008:20:49:03 +0100] “POST /egroupware/xmlrpc.php HTTP/1.1” 200 293 “-” “XML-RPC.NET”
What’s the problem?
I searched but I didn’t found any solution…
Thank you very much for your help!
Bye.
