root@egw21:/home/atsrl# docker logs -f egroupware
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,)P|gnB;Evk&_7hPp’
Retrying EGroupware installation in 5 seconds …
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,LaftS9Bgs|>W6-)F’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,v91tftCq8XadvL-&’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,Fks-P4!DlX3a0>#T’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,[Ivnu5S6e!2Uae2B’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,CmiVqJTQL!}@_Ci7’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,B6;5foXfB>cUkyo}’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,J4TQcJ4_q@#>))ds’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,)EEtrLvso@ti2dI0’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,BM!5H>OL!GN:[p#?’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,<Z]kaGk8wbV4]T(P’
/usr/bin/php8.4 -d memory_limit=-1 /usr/share/egroupware/setup/setup-cli.php --update ‘all,admin,RFo:8OW8X9Lk?xwE’
Installing of EGroupware failed!
- Starting periodic command scheduler cron
…done.
[16-Jul-2025 04:03:25] NOTICE: fpm is running, pid 1
[16-Jul-2025 04:03:25] NOTICE: ready to handle connections
[16-Jul-2025 04:03:25] NOTICE: systemd monitor interval set to 10000ms
[16-Jul-2025 06:14:25] NOTICE: [pool www] child 85 exited with code 0 after 7860.358831 seconds from start
[16-Jul-2025 06:14:25] NOTICE: [pool www] child 369 started
[16-Jul-2025 06:14:25] NOTICE: [pool www] child 84 exited with code 0 after 7860.362401 seconds from start
[16-Jul-2025 06:14:25] NOTICE: [pool www] child 370 started
[16-Jul-2025 06:14:25] NOTICE: [pool www] child 86 exited with code 0 after 7860.592857 seconds from start
[16-Jul-2025 06:14:25] NOTICE: [pool www] child 371 started
[16-Jul-2025 06:14:26] NOTICE: [pool www] child 87 exited with code 0 after 7861.176169 seconds from start
[16-Jul-2025 06:14:26] NOTICE: [pool www] child 372 started
[16-Jul-2025 06:14:26] NOTICE: [pool www] child 91 exited with code 0 after 7861.386791 seconds from start
