Hi Hans-Jürgen,
Hi!
I just tried to import a *.zip backup from one eGroupware trunk install
into another eGroupware trunk install and received the following error
PHP Warning: fopen(compress.bzip2:///tmp/phpP6dIGP.bz2): failed to open
stream: operation failed in
/usr/local/src/egroupware-trunk/phpgwapi/inc/class.db_backup.inc.php on
line 240
[Thu Sep 22 21:06:46 2011] [error] [client 88.69.228.170] PHP Warning:
fopen(compress.zlib:///tmp/phpP6dIGP.gz): failed to open stream:
operation failed in
line 241
Have a look in PHP-Info if compress.bzip2 is a registered PHP stream
(only if you have AFAIK bz2 extension installed).
Does the file exists on the server and is a bz2 file?
[Thu Sep 22 21:06:47 2011] [error] [client 88.69.228.170]
egw_minimal::__get: There’s NO system_charset object! egw_minimal->__get:641
What could cause this, how is the message to be interpreted?
Did anyone successfully use the backup / restore lately?
Thanks for a hint,
Hans-Jürgen
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2dcopy1
