Habe eben upgedatet.
Der Wechsel in einer Kalenderansicht z.B. auf die nächste Woche dauert ca 60 sek.
Die beiden ausgefüllten Rechtecke sind Termine, die auf dem Handy korrekt dargestellt werden.
Gelegentlich kommt eine Meldung im Firefox, dass die Webseite den Browser verlangsamt. (oder so ähnlich)
Im z-push log tauchen noch Loop’s auf :
02/07/2026 14:19:06 [22479] [ERROR] [uwe] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command ‘Sync’ at 02/07/2026 14:18:07 with pid ‘22469’ terminated unexpectedly or is still running.
02/07/2026 14:19:06 [22479] [ERROR] [uwe] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
02/07/2026 14:19:12 [22195] [WARN] [uwe] /usr/share/egroupware/tracker/inc/class.tracker_bo.inc.php:1887 Undefined property: tracker_bo::$show_dates (2)
02/07/2026 14:19:12 [22195] [WARN] [uwe] /usr/share/egroupware/tracker/inc/class.tracker_bo.inc.php:402 Undefined property: tracker_bo::$default_tracker (2)
02/07/2026 14:19:13 [22201] [ERROR] [uwe] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command ‘Sync’ at 02/07/2026 14:18:15 with pid ‘22759’ terminated unexpectedly or is still running.
02/07/2026 14:19:13 [22201] [ERROR] [uwe] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
02/07/2026 14:19:19 [22706] [WARN] [uwe] /usr/share/egroupware/tracker/inc/class.tracker_bo.inc.php:1887 Undefined property: tracker_bo::$show_dates (2)
02/07/2026 14:19:19 [22706] [WARN] [uwe] /usr/share/egroupware/tracker/inc/class.tracker_bo.inc.php:402 Undefined property: tracker_bo::$default_tracker (2)
02/07/2026 14:19:20 [22757] [ERROR] [uwe] LoopDetection->ProcessLoopDetectionPreviousConnectionFailed(): Command ‘Sync’ at 02/07/2026 14:18:24 with pid ‘21912’ terminated unexpectedly or is still running.
02/07/2026 14:19:20 [22757] [ERROR] [uwe] Please check your logs for this PID and errors like PHP-Fatals or Apache segmentation faults and report your results to the Z-Push dev team.
