I have a custom type for addressbook, called ‘Property’, and it uses a template called ‘addressbook.Property.edit’. (I check in the custom fields and verify that this template is assigned to these ‘Property’ items.)
In recent revisions (testing r43883 right now) EGW doesn’t seem to be able to find this template anymore. I’m not sure how to get this working again.
Error says:
WARNING: Template “addressbook.Property.edit” not found, using default template instead. Update the template name in custom fields section!
I’d appreciate any tips or tricks to work around this,
Regards,
Paul
