The templates are stored in the db, simply access the db and put them there.
Before you ask about the format: look at the code or better use it, to
write the templates to the db.
Artem Sitnikov schrieb:
ralfbecker wrote:
Nope, thought I fail a bit to understand why you want that anyway?
I have a question about eTemplate.
Can I create or modify template with xml-rpc?
Dear Ralf,
I will try to explain what I want.
I have several domains in eGroupware.
I want them to be different in design, color etc.
I want to make these changes by using xml-rpc.
Is it possible?, if yes could you give me some instructions how to do it?
Best, Artem
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 7815917
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
