Hi Pierre,
Hello,
I have an issue with eTemplate2:
[Mon Aug 04 14:12:29 2014] [error] [client xxx.xxx.xxx.xxx] Error
storing etemplate request data for
id=emailadmin_firstuser_53df78ad114d38.01096041!, referer:
http://mydomain/index.php?cd=yes
This error means that caching is NOT working! This is really serious,
your EGroupware will probably not work.
EGroupware selects it’s caching backend by default automatically:
- if a APC compatible shared memory cache is available, that the first
preference, if it has more then 128MB available
- if APC is not available or to small, we cache into temp. directory
specified in setup
- there are more backends, but they need to be manually enabled eg. in
header.inc.php file
So you should check if temp. directory you specified exists and is
writable for the webserver. Or even better install APC or APCu and give
it at least 128, better 256MB (apc.shm_size * apc.shm_segments).
Most EGroupware apps will not work, if you dont fix that issue!
and
[Mon Aug 04 14:14:42 2014] [error] [client xxx.xxx.xxx.xxx]
etemplate_request::read(‘admin_firstuser_53df7837dcec87.39376105’,
…) eT2 request not found / expired --> redirecting app admin to
/index.php?menuaction=admin.admin_ui.index&ajax=true
(_GET[menuaction]=admin.etemplate_new.ajax_destroy_session.etemplate,
isJSONRequest()=TRUE), referer: http://mydomain/index.php?cd=yes
With that some applications don’t work correctly, like the new mail
client…
I feel that the problem comes from a mistake in configuration of the
cache folder, but I don’t know where it is located and how to change
it (if needed)
Setup (upper login) >> Edit current configuration: full path for
temporary files
