Hi, ich habe es jetzt geschafft Felamimail zu installieren, jedoch bekomme ich jetzt eine Fehlermeldung von PEAR:
Warning: require_once(PEAR.php) [function.require-once]: failed to open stream: No such file or directory in /mnt/web4/41/04/51239404/htdocs/egroup/egw-pear/Net/Socket.php on line 22
Fatal error: require_once() [function.require]: Failed opening required ‘PEAR.php’ (include_path=’/mnt/web4/41/04/51239404/htdocs/egroup/egw-pear:’.:/opt/RZphp5/includes/PEAR.php’’) in /mnt/web4/41/04/51239404/htdocs/egroup/egw-pear/Net/Socket.php on line 22
Was muss ich ändern?
Hier ein Auszug aus meine info.php
PHP Version 5.2.2
‘./configure’ ‘–prefix=/opt/RZphp5’ ‘–with-jpeg-dir=…/local’ ‘–with-gd’ ‘–with-png-dir=…/local’ ‘–with-freetype-dir=…/local’ ‘–with-expat-dir=…/local’ ‘–with-iconv-dir=…/local’ ‘–with-iconv=…/local’ ‘–with-mysql=…/local’ ‘–with-mysqli=…/local/bin/mysql_config’ ‘–with-libxml-dir=…/local’ ‘–with-zlib=…/local’ ‘–with-zlib-dir=…/local’ ‘–with-db2=…/local’ ‘–with-ndbm’ ‘–with-gdbm=…/local’ ‘–with-mhash=…/local’ ‘–with-mcrypt=…/local’ ‘–with-bz2=…/local’ ‘–with-zip=…/local’ ‘–with-xsl=…/local’ ‘–with-ming=…/local’ ‘–with-idn=…/local’ ‘–with-gettext=…/local’ ‘–with-imap=…/local/c-client’ ‘–with-tidy=…/local’ ‘–with-mssql=…/local’ ‘–with-sqlite’ ‘–enable-mailparse’ ‘–enable-mbstring’ ‘–disable-mbregex’ ‘–disable-hash’ ‘–enable-yats’ ‘–enable-dba’ ‘–enable-discard-path’ ‘–enable-sysvshm=yes’ ‘–enable-sysvsem=yes’ ‘–enable-debug=no’ ‘–enable-bcmath=yes’ ‘–enable-safe-mode=yes’ ‘–with-exec-dir=/opt/RZphp5/exec’ ‘–with-config-file-path=/opt/RZphp5/etc’ ‘–enable-memory-limit’ ‘–enable-pear’ ‘–enable-pcntl’ ‘–enable-calendar’ ‘–enable-dbase’ ‘–enable-wddx’ ‘–enable-trans-sid’ ‘–enable-ftp’ ‘–enable-exif’
Danke schon mal für eure Hilfe.
P.S. Mein Provider ist Strato
