That’s the reason, why we only support utf-8 in Trunk. So do yourself a
favor and convert your installation to utf-8.
1.8 still works with other charsets, but it is NOT recommened, nor can
your create new installs with charsets other then utf-8.
Hello,
since the new json-module I had the problem, that felamimail doesn’t refresh
correct.
After intensive debugging I’ve found the problem. On the server isn’t UTF-8
default charset. So it breaks the json_encode-function on the first
non-UTF-8-character.
Here is my patch/workaround:
Index: class.egw_json.inc.php
— class.egw_json.inc.php (Revision 32205)
+++ class.egw_json.inc.php (Arbeitskopie)
@@ -397,6 +397,29 @@
- public function utf8json($inArray) {
- static $depth = 0;
- /* our return object */
- $newArray = array();
- /* safety recursion limit */
- $depth ++;
- if($depth>= ‘30’) {
return false;
- /* step through inArray */
- foreach($inArray as $key=>$val) {
if(is_array($val)) {
/* recurse on array elements */
$newArray[$key] = self::utf8json($val);
} else {
/* encode string values */
$newArray[$key] = utf8_encode($val);
- /* return utf8 encoded array */
- return $newArray;
- Returns the actual JSON code generated by calling the above "add"
function.
@@ -409,7 +432,7 @@
/* Wrap the result array into a parent “response” Object */
$res = array(‘response’ => $inst->responseArray);
JSON_HEX_QUOT |
JSON_HEX_AMP);
JSON_HEX_APOS |
JSON_HEX_QUOT | JSON_HEX_AMP);
Georg Klimm
LOHN24.de GmbH Internetlohnabrechnungen ila
Hausanschrift: Jahnstrasse 35 * 12347 Berlin
Postanschrift: Postfach 47 06 69 * 12315 Berlin
Tel: +49 30 66909200 * Fax: +49 30 6644208
Internet: http://www.lohn24.de
AG Berlin-Charlottenburg HRB 92027
Geschäftsführer Hans-Joachim May
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
