backup
you create a new type
move all d-types to the new type e.g. via SQL
remove the old dt-ype
backup again(, just in case)
done
you may manipulate the addressbook types in egw_config directly.
its a serialized array, so be careful. dame with contact_tid
you may manipulate is directly via sql. it may be faster.
make sure, your D types are not mixed, with “marked as Deleted” addresses
no easy way to solve that one
klaus
kl@stylite.de
Developement
[ open style of IT ]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon 06352 . 70629-0
fax 06352 . 70629-30
