The last step of registration crashes with a blank screen when the method accounts->autoadd is
run. I don’t exactly understand why it crashes but when I disable the following hook everything works fine.
$setup_info[‘felamimail’][‘hooks’][‘addaccount’] = ‘felamimail.bofelamimail.addAccount’;
I now use a workaround function in Registration which temporary disables the felamimail hook, but
this is not the best solution.
Is this a misconfiguration of my installation? Must I run php5? Or is this a Felamimail bug?
Greets,
Pim
Lingewoud B.V.
Achter 't Veer 12
4191 AD Geldermalsen
The Netherlands
Tel. +31 3455 82222
Fax. +31 3455 70090
