On Debian using the sources:
deb
http://download.opensuse.org/repositories/server:/eGroupWare/Debian_6.0/ ./
you may install : egroupware-egw-pear
Hi I had installed the all EWG application but I had a problem with
felamimail and
EMailAdmin had this error: emailadmin-Fallo en las
dependencias:(appname: phpgwapi; versions: 1.7,1.8,1.9; appname:
egw-pear; versions: 1.8,1.9; ))D.
And on FeLaMiMail : felamimail-Fallo de dependencias en el proceso de
post-instalación:(appname: phpgwapi; versions: 1.7,1.8,1.9; appname:
emailadmin; versions: 1.7,1.8,1.9; appname: egw-pear; versions: 1.8,1.9;
))P.
Also it said that need egw-pear but I did not know where I can get this
application and how to install.
If someone can help I will appreciate. This is my first time in doing
this and I really need some help.
Ing. Carolina Diloné
Helpdesk
(809) 581-8541 ext.273
www.coopaltagracia.com http://www.coopaltagracia.com/
/2013: “Año de la Excelencia en el Servicio”/
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap1
Mauricio Milne - Santa Fe, Argentina
LUNIX S.R.L. - (54) 342 4881222
Soluciones en GNU/Linux - http://www.lunix.com.ar
GTALK-MSN-JABBER ID: mauricio@lunix.com.ar
gpg --recv-keys 0x6F8838D6
