I’ve experimented just the same problem you describe here. I solved it by adding 127.0.0.1/32 to the mynetworks variable in main.cf , the postfix main configuration file. After that I can send email to external domains with no problem.
Hope it works for you too.
David
Thanks for the hints.
YES and YES, I can send emails to different email addresses
which dosen't belong to our domain using horde webmail. Even
KMail and thunderbird are working well with that smtp to send
emails. BUT felamimail has problem to send emails rather than
the default domain set in emailadmin. please help to fix the
problem or is it a bug in egroupware
> Just make shure you can use the same smtp server from your
horde
> webmail.
> Check with your hosting if they allow the use of the same
smtp server
> for any other app then their horde webmail.
> It look indeed as if you don't have the rights to send trough
this
> smtp server.
> Atherwise send in your config, might also be a typoerror?
> Cheers,
> Remco
> Op 5-dec-2006, om 10:42AM heeft egroupware-users-
> request@lists.sourceforge.net het volgende geschreven:
> > Message: 7
> > Date: Tue, 5 Dec 2006 08:00:50 GMT
> > From:
> > Subject: Re: [eGroupWare-users] felamimail problem with SMTP
> > To: discussions and questions of users for users of eGroupWare
> > Message-ID: <200612050800.kB580m4m028216@um1.unlimitedmail.net>
> > Thanks for the response, I have already set *relay on* in the
> > PLESK email configuration. More over I have no problem with
> > SMTP when using the Horde webmail. But with egroupware it is
> > really a problem to send mails other than the SMTP setting of
> > emailadmin. If you need more information about my smtp
> > configuration please let me know.
> >> sounds like a relay issue to me, but i dont know the
> > particulars on your
> >> host provider. I know my home account requires ALL outgoing
> > emails to be
> >> sent via their smtp server.
> >> jer
> >> j.bakshi@unlimitedmail.org wrote:
> >>> Hi,
> >>> I have no problem to receive mails using IMAP server through
> >>> felamimail. But there is a strange problem in felamimail
> >>> regarding SMTP. I can send to mails only to those domain
which
> >>> is set to the SMTP section of emailadmin. But no outgoing
> >>> mails are working with adifferent domain. Like I can send
mails
> >>> to infoservices.in which is set to the smtp section of
> >>> emaiadmin but I can't send mail to gmail.com or any where
else
> >>> except infoservices.in. Is it a bug in felami or there is any
> >>> way to
> >>> implement so HTTP can send mails to other domains too ?
> >>> thanks
> Take Surveys. Earn Cash. Influence the Future of IT
> Join SourceForge.net's Techsay panel and you'll get the
chance to share your
> opinions on IT & business topics through brief surveys - and
earn cash
> _______________________________________________
> eGroupWare-users mailing list
> eGroupWare-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/egroupware-users
Message sent from the
Unlimited Mail Free Services Platform.
http://www.unlimitedmail.net
[/quote]
