Hi I have digged a little bit in the code for calculating the list size for E-Mails. It is the “height” for the element tdAppBox which seems to be calculated wrong. I don´t know why the function “handleResize” is called twice but that is not the problem. I have seen that you use the div “sideBox” for more than one item (EMailgroup-tree, Admin-Menu, Setup-Menu,…) but you did not count this sizes in? E.G I have a documentheight of 943 in the first run but it is reduced to a height of 654 in the second run.
I can´t figure out why you div the docheight by 3.
I´m using an actual svn-checkout of “trunk” on an actual debian with win7 and XP firefox and IE as client.
Greetings from Bonn, Germany
