Hi Chris,
Hello everyone
I know that this topic has been touched more than a few times, but after
searching the forum I have not found an answer.
The problem is the following:
When I try to access Felamimail, egroupware takes AGES to show a blank
screen, but when I take away my IMAP config from setup, it instantly shows
me that I do not have IMAP config.
My php.ini is configured to instruccions, when I do a config check in setup,
all the necessary settings pass, and I have pear installed and configured.
I am using PHP 5.2.4, which comes with xampp 1.6.4,
It’s quite an old PHP version, thought I’m not aware of any problems.
and i am using Kerio Mailserver version 6.7.3 Patch 1
AFAIK we have no experience with Kerio mailserver.
Are you using the current community version 1.8.001.2010111?
If not the first thing to do it, to update to the current version.
If that does NOT help, the quickest way is to buy a small support budget
(http://www.stylite.de/egroupware_consulting_and_support) and send us
credentials for one mailbox on your server.
I have checked the error log and nothing appears, also I have tried various
configurations in the imap setup (localhost, 127.0.0.1, the servers IP
address and the public IP address) with no change.
I am now not sure if it is my version of PHP that is causing the problem or
something else, help with this problem would be greatly apreciated.
Thanks
Chris
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Centralized Desktop Delivery: Dell and VMware Reference Architecture
Simplifying enterprise desktop deployment and management using
Dell EqualLogic storage and VMware View: A highly scalable, end-to-end
client virtualization framework. Read more!
http://p.sf.net/sfu/dell-eql-dev2dev
